I’ve recently purchased the Wyze Smart Bulb designed to operate on 110vac through a ‘standard’ bulb socket.
QUESTION: Can the internal 110vac “Transformer circuit” that feeds; (1) the DC ‘firmware operation’; and then (2) the DC LED lighting circuit, be isolated in order to use all “low voltage DC” as in ‘rechargeable battery packs’?
It would be relatively simple to do a ‘teardown’ in order to “direct wire” the LED’s - but all other functionality would be lost. I’d rather NOT use a 12vdc to 110vac inverter as space is a consideration.
