My sence is closed but on the app shows open. When I open it I get an alert. When I close it I do not get an alert and it still shows open in the app. Any ideas?
Try removing the product and adding it back.
I have the same problem too. I don’t think the solution should ever be to remove and re-add it. If it stops working it’s a problem.
Hello @livetoofight @tdjanke, I recommend that you take the Wyze sense bridge out of the camera it is getting power from then reconnect it after 10 seconds to see if it fixes the issue.
Tried it and still no luck.
I’m having the same issue. One contact sensor works great, the be other constantly shows as open.
