Wyze scale - tune body stats
It would be great if there was a way to enter the body stats (ex: fat and muscle percentage) that you get from a dexa scan to help tweak the algorithm.
I imagine if it knows what the values are at the time you enter them, then it can tweak the algorithm to compute the difference over time to have a much more realistic value.
Right now my scale thinks I am at 13% body fat which is way off. I’m more like around 20 to 22%. Really I’m not sure how the algorithm can be so far off but it would be amazing if I can just tune it in the right direction.
Right now the data is so far off that honestly I would love a way to just disable it. It keeps sending data to my Fitbit that is completely off. At that point I would rather just have manual data entered into my Fitbit every time I do a dexa.
