We have a scale X, but it doesn’t provide accurate body fat %. The weight is accurate, but not body fat %. For context, our old scale showed 23%. A recent Dexa Scan showed 23.1% (the gold standard measurement). But our Wyze scale shows 19% … which is a pretty big difference.
We have made sure the firmware is up to date and the athlete mode is off.
I don’t have a Dexa scan to compare against, but a thought, having identified athlete mode, have you tried changing the Body Type to see if the reading changes?
So I was using a Scale S. I switched to Ultra Body Scan. HUGE difference in all metrics except for the weight.
It’s because Scale S (and your Scale X) use 4 electrodes. That only measures your lower body. Your upper body is estimated. An 8 electrode scale (Ultra Body Scan) is far more accurate because it actually measures your upper and lower body. That’s the reason I switched.
I don’t have a Dexa scan to compare it to, but every bit of research I’ve done shows that 8 electrode scales are much more accurate when it comes to body fat %. Even so an 8 electrode scale still has an error rate of +/- 3-5%. It’s never going to truly match a Dexa test (which itself has a +/- 1-2% error rate).
In my opinion, 4 electrode scales are best for tracking trends, not actual body fat %. 8 electrode scales are better, and closer to being accurate.
