I bought a wyze scale (The original one with the silver cube in the middel) and it worked fine the first few days. After a few weeks i hadn’t used it in a while and tried using it but nothing happened. Changed batteries and now it shows (CAL 0) on the display and after few seconds shows (CAL 1) on the display. It doesn’t do anything and i cant weigh or add it to my wyze home. What do the display messages mean and how do i fix it? It just keeps showing (CAL 1) forever unless i remove batteries.
I am sorry this is happening. I would try contacting support about this issue, they may be able to help.
