Wyze Scale S, Sprinkler, Light Strip & Light Strip Pro Firmware Beta Test 3/30/2022
Wyze Scale S:
Version 1.0.107
What’s New:
  • Resolved Bluetooth connection conflicts between Wyze Scale, Wyze Watch, and Wyze Band for Pixel 6 and Pixel 6 Pro
  • Changed error code C to error code CAL
Wyze Sprinkler Controller:
Version: 1.0.8
What’s New:
  • Fixed a bug that caused Quick Run and Schedules to stop immediately after starting
Wyze Light Strip:
Version: 1.1.1.142
What’s New:
  • Updated logic when reporting offline issues
  • Updated implementation for timer, vacation mode, sleep routines, Sun Match, and Rules
  • Improved Music Mode performance
  • Improved color calibration
Wyze Light Strip Pro:
Version: 1.1.1.143
What’s New:
  • Bug fixes
I recently did the update from 1.0.4 to 1.0.8 but it said that it failed. I waited a while and tried again with the “update failed” message popping up immediately. I then powered the controller off, let it sit a bit, powered it back on, and it still says “update failed”. When I tap on “Update Failed” it briefly says “updating” but then immediately returns to “update failed”. However, when I check the firmware level for the controller it says 1.0.8, so it does look like it actually updated. How can I get rid of the “update failed” message when I go to the firmware update section of the app?
