Wyze Scale improvments (and starting screen)
Hello all,
I’ve been using the Wyze scale S for some time now and i have a couple of suggestions for the developers. I apologize if any of my suggestions are resolved const and i overlooked them. Any positive criticism is welcomed.
It would be great if there was an way of moving around the gadgets give them priority in the list, even group them. For instance i would put all the plugs in one folder and collapse it, since they are programmed to be on a timer and i don’t need to access them at all. It would also be handy if i can move the Scale on the top of the list so i can access it faster each time i open the app.
On the Scale, i think that a custom range would be really great. You would be able to track your fitness goals easier if you started on a set date, then you’d only refer to that range of time.
I was looking at this measurements and it would be really helpful if we can combine both weight and percentage, as showed in my images above. I don’t know if this would be a option that the user should have, or it would be by default, but i been keen to know if my workouts are helping me lose any body fat or not. Showing the percentages only accounts for the ration between the mass and the body weight, where a lbs measurement would be way more accurate for an individual goal
I couldn’t quite figure it out, what is the difference between Lean Body Mass and Muscle Mass
Please let me know if you have any questions and/ or comments that i can answer on this specific scenario
