I was setting up some rules based on Smoke and CO alarms. I noticed that I can only do this with V2 cameras and it doesn’t seem to be available to V3’s. Is this a bug or is this as intended?
All Cameras and Wyze app are up to date.
Yes, apparently at this time, that is only available on V2 cameras.
NFD
That is disappointing that the newest hardware doesn’t have the same features but at least now I know I’m not doing something wrong!
Thank you!
I have them linked to my HMS (v11) App 2,22.21 ?
I am able to link them in both the HMS & V3 Cam.
I don’t use HMS so that won’t work for me but glad it works for you
Okie Dokie !
Sounds, like you should contact support on line to troubleshoot, the issue.
Hopefully, they’ll issue an app / cam update / fix.
Seems odd since you can change camera settings to send an alert and record video.
