I set up Sound triggers on two of my V3 cameras but they do not work at all. Had anyone had any luck getting triggers to work on V3’s? Any trick to getting them to work?
I don’t use the Sound events, but am curious if you have it setup on the Camera itself? It may be needed for the rule to fire.
- Under Event Recording, CH=heck the Detects Sound
- In notifications, you can also turn that on if you would like.
Note: you may need to adjust sound sensitivity
I see the same problem. Is the sound trigger still not working?
