Wyze Propane Tank Meter/Scale
I currently live in a rural area where natural gas is non-existent. All of the communities around me everybody uses propane and big propane tanks. It happens to me time and time again where I forget to check the propane. I run out and it is so frustrating. If there is any possibility of a way you guys can create a wyze propane meter. Possibly even solar powered.
A possible workaround would be to place a cam monitoring the gauge on your tank. That way at least you could remotely see the gauge and know your status from anywhere.
Set a reminder with Siri, Alexa or any reminders app to prompt you to look and you are at least better off.
BTW - you can Vote for your own Wishlist topic. Since at the moment here are 0 votes I see you didn’t - jump back in!
I rent my tank from my propane company, and I’m 99% sure they would not permit me to install an electronic gauge on it. If there was one available, it would have to be approved by them, and they would be the ones to install it due to liability issues. Personally, I wouldn’t want to put a constantly on, possible electronic ignition source on an 800-lb. propane tank. Call me paranoid…
An ullage gauge would probably not be allowed. A scale gauge probably would, but it would depend on how ungainly the tank is. A pressure gauge would not be very useful.
I used to work in the remote sensor tank industry.
This would be awesome, I rent my 500lb tank and my propane company has a wireless gage on my tank so they know when they need to send someone out to fill it up. I was thinking of buying a tank and this would be a convenient add on.
I would like to put the scale under my BBQ grill propane tank to monitor how much is left.
A mod. On the wyze scale could do that .
I too have a 100 gallon buried propane tank that provide no remote means of measuring consumption. Upon researching a remote measuring device, I found a Generac device that costs about $225. I was ready to buy it, but then learned that they charge about $80 for an annual subscription to provide the app to read the propane level. This is akin to Chevy charging a fee for a gas gauge on the dashboard – who would ever pay for that???
So I completely agree that this is an excellent suggestion for Wyze to build a measuring device for propane tanks. There are 7M homes that run on propane in addition to RVs, grills, and houses with propane fireplaces. All Wyze has to do is watch the Generac Youtube and they’ll learn that Generac’s solution is cell phone technology. What’s needed is a WIFI technology. When and if Wyze introduces this product, I’ll gladly purchase it. I believe every propane supply company out there would be excited to be able to offer this product to their existing customers and prospects.
I know this is a 3 yr old post, but I’ve tested the concept of installing a small wireless camera with a magnet to view the analog gauge already installed on the 100 gallon propane tank. The image was somewhat blurry, but focused enough I can see when it’s approaching 30% which my supplier recommends as a refill point. So I’m looking to buy a new outdoor battery cam (brand to be determined) with a solar panel.
I have a bunch of older V3 magnetic bases, so I would like to use one of those. That said, it would be helpful if a Wyze Support Admin could tell me if the Wyze Cam V3 magnetic base and screw can be attached to the Wyze Battery Cam Pro or Wyze Cam Outdoor.
For all I think the best options right now is:
https://www.amazon.com/Mopeka-Wireless-Propane-Monitor-Residential/dp/B0BKLFQ3CL?ref_=ast_sto_dp
Depending on your size needs…
I DEFINITELY THINK this is SOMETHING THAT should BE RECONSIDERED as fitting into the whole home monitoring system…
Maybe contract with these people to get a branded setup that can integrate into the HMS or a gateway to bridge into the Wyze systems… They seem to have the components and just likely some software to work it in…
Voted! SUGGEST RECONSIDERATION! And do this! I don’t even have a use for it, but still DO IT! :slight_smile: :wink:
@rec9140 Coincidentally, that is exactly what I ordered and installed before testing one of my Wyze V3’s. There are a few issues with the Mopeka.
First, it only uses a bluetooth connection back to my house 20’ away, even when I’m standing at the window. Second, their application cannot find the device 50% of the time I check while standing next to the tank. And third, there is no support, no replies to support tickets or email. I’m returning it to the manufacturer this week. I’m going to try a Wyze Cam instead and just use double sided tape to position it. That’s better than nothing I suppose.
It would be great if you could add an LP Tank monitor like this. Wireless Propane Tank Level Monitoring Sensor
Wireless Hall Effect Module for Rochester Remote Ready Dial (R3D) for Liquid Propane (LP) Tank
Wyze wireless climate sensors, leak detectors, and and entry sensors for the Wyze Sense Hub are great for remote monitoring temperature, leaks, and entry over the Internet.
Rochester Sensors sells a Remote Ready Dial that can be used as a retrofit on liquid propane (LP) tank gauges, and a wired Hall Effect Module that snaps into the Dial to provide an electrical output which can be utilized for remote monitoring of tank levels. The Hall Effect is a solid state technology with no moving contacts. It counts on the fact that a magnet bends the path of electrons moving through a semiconductor. The bending of the electron path can be detected and converted into an electrical signal. https://rochestersensors.com/wp-content/uploads/R3D-LP.pdf
Would it be possible to create a wireless Hall effect sensor for the Wyze Sense Hub that would snap into the Rochester Remote Ready Dial, and would send a signal to the Wyze Sense Hub indicating the propane level in the tank?
I considered using a Wyze Cam to monitor the propane tank gauge, because I already use a Wyze Cam to remotely monitor my oil tank gauge. The oil tank is in the garage, so I plugged the Wyze Cam into a nearby outlet, and mounted it on the oil tank near the gauge. However, the propane tank is outside, far away from an electric outlet.
Marc6, Since your propane tank is outside (like mine), use the WYZE Solar Cam Pan. It’s solar panel eliminates the need for a power source. My camera clearly shows the gauge night and day.
That’s an excellent idea. Could you send me a photo of how you mounted the Wyze Solar Cam, and also a photo of the gauge as seen by the Solar Cam? Thanks.
My camera is mounted on the access lid to my underground tank. If your tank is not underground, I suggest you mount it above the tank looking down on the gauge from either your house or strap an extension arm to the tank to hold the camera. Because my camera is so close to my gauge with the lid closed, I added the Wyze closeup lens ($10) to the camera Wyze Cam Close-up Lens
When I tried to send the pictures of the mounted camera, this substandard messaging platform Wyze uses gives me this message: An error occurred: Sorry, new users can only put one embedded media item in a post.
So, Here’s another picture:
Ha ha ha … This is the warning when I tried to send this last picture:
An error occurred: You’re replying a bit too quickly. Please wait 7 seconds before trying again.
That’s Discourse’s way of telling you that you need to spend more time here.[1] :wink:
That’s excellent! This is the first mention I’ve seen of anyone using this on Solar Cam Pan. :+1:
Are you using the Cam’s spotlight to see the gauge when the lid is closed, or do you get sufficient light through the vent?
  1. Your profile shows that you’re currently a “New User (TL0)”. You can get to TL1 with just a little bit of effort, and that will remove the 1-image-per-post restriction. ↩︎
I checked and learned the camera has night vision, so it sees the camera like that all the time. I’ve been checking it randomly during days and nights and it looks the same every time. I’m quite happy with it.
For fun, I want to wait until my neighbor walks by and I’m going to use the microphone to yell to him from inside the enclusure “Help –I’m stuck and I can’t get out.”
