Is there any type of record kept when the plug is scheduled or in use? If there are records of when there is motion on Wyze servers for many days, I’m curious if something is kept with regards to the plugs.
When it is scheduled? The rule itself will tell that info. When the schedule was ran? Check rules history.
I just bought them. I was just curious if that is the case.
