A power issue knocked all my wyze stuff offline, and most of the plugs came back after unplugging them for a few seconds. But one now does nothing, no blue light no matter what I do. Is it dead, or is there a last-ditch option?
First thing I would try is to move it to another outlet. It could be that the outlet is bad, maybe a GFI needs to be reset. If that does not work, you could try a Factory Reset if the Blue Light does not go on. If it still does not work, it may be dead.
It’s dead, all right. My Wyze products are dropping like flies!
