Wyze Plug multiple on-off / duty cycle
Wishlist item here. Looking to have the plug programming allow for a duty cycle, So “on” for 20min “off” for 40min. Repeating until changed. As of now you can only have the plug turn on or off in a set time period just the once.
Thanks!
What’s the problem with using two Device & Service Trigger Automations for this?
    • IF
      • Wyze Plug
        • Has been on for 00:20:00
    • DO
      • Wyze Plug
        • Turn off
    • IF
      • Wyze Plug
        • Has been off for 00:40:00
    • DO
      • Wyze Plug
        • Turn on
If it’s a repeating cycle that you want to run for only certain hours of the day or only on certain days, then you can also complete the WHEN section of each Automation. Additionally, you could create a couple of Schedule Automations (if necessary) to start and stop the cycle with the “on” or “off” phase (as desired) at certain times each day.
Look at the Sonoff S31 wifi plug. As many cycles as you wish, and also has a “loop” feature. ittead.cc or https://us.itead.cc/us or Amazon
