The new proprietary 90° microUSB cord on the Pan V3 has produced a lot of discussion in the forum.
But, be aware that the 90° microUSB plug was specifically designed for the cam to seal the power port and make it weatherproof compliant. If you are using it outdoors with any other cord, the plug is not weatherproof and the warranty is voided if it fails due to water intrusion which is likely without the sealing plug that came with it.
