Using a standard USB power connector will compromise the waterproof rating of the Outdoor camera, so this isn’t recommended. The Solar Panel has a properly sealed connector on it, however.
You are correct. Should have said that. But was going to recommend a V3 instead of the WCO. Was not recommending it for the WCO.
Thanks for clarifying.
Just to clarify, this dead one was almost totally sealed. the SD slot at the bottom was little loose by defect, it just refused to be totally close.
None of the units were wired.
Anyhow, do I get it replaced under warranty? under 3 months.
You should get a friend to camp in the bushes at night lol I’d spray them with silly string for you ! Hope you get these perpetrators , might be time for a new camera maybe it’s covered by warranty still you can always contact support and ask . Plus national pumpkin smashing day is coming I hope you are prepared
LOL. Yes, I have been in touched with support and they will either issue a replacement or account credit.
Camp out friend sounds good too.
We have the big problem with these catalytic converter thieves here in CA.
