My wyze lock bolt is having a problem. When you unlock it via finger print, code or via app it unlocks but the second it unlocks it automatically locks in less than a second. On the app it says it is unlocked but the bolt is locked. Manually turning the bolt to unlock then trying it again will yeild the same result but in reverse. Currently unlocked (manually), locking it will lock and automatically unlocks after. I have tried changing batteries (100% charge), factory reset, resitting the bolt, etc. But still same result. Auto lock is disabled also.
