Wyze door bolt does not support wifi. However if the device can connect to wyze app via bluetooth it should also theoretically be able to connect to echo show newer gen devices. That way it can be controlled away from home despite having no wifi since the echo device can relay instructions. This should be a MUST have feature integration with the skill. Is there any plan to integrate that?
Welcome to the forum @zzkaustavzz
This would make an excellent wishlist item. I’d give it a vote.
