Wyze Light Strip & Pro Beta Firmware Test 6/21/2022
Light Strip Beta:
Version: 1.1.1.156
What’s New:
  • Added support for a blinking light Rule
  • Improved connectivity
Light Strip Pro Beta:
Version: 1.1.1.157
What’s New:
Applied update, FW update went fine for
Light Strip Pro 32ft
Light Strip Pro 16ft
Light Strip 32ft
After install did a quick smoke test, changed a few of the brightness settings and colors for each strip. The light strip Pro 16ft did not respond to any of the changes. After 4 attempts unplugged the controller for 10 seconds, and plugged it back in. The strip then began responding to the standard color and brightness changes.
Will continue to monitor and provide any feedback.
Thank You
Applied to my Light Strip Standard and Pro. All functioning as expected. Performed the udpate via he Firmware Update Page
I set up a new pro 16 ft strip just the other day and although I could control it I noticed I couldn’t set any rules for it. Unplugging it for 10 to 15 seconds also did the trick for me.
