Wyze IFTTT and Smart Life Groups
Hello,
Not sure if anyone has experienced this issue but I have several groups of lights in my smart life app. For example, 4 kitchen lights are under Group kitchen lights. Same for hallway and outside lights.
I set the motion sensor to turn on my group basement lights on motion and on clear, turn the group basement lights off. It was working well for a while. Then recently when the motion sensor clears, it turns off all group lights. I re configured it and the same thing happens. My only solution is to trigger for every specific light and not group. So far this work around is successful but very inefficient.
Unless I misunderstand, this sounds like an IFTTT to Smart Life service issue.
The Wyze motion sensor is just a trigger (That) to IFTTT. It doesn’t have any control of what IFTTT does after IFTTT gets the trigger.
Agree with @None. I have currently three motion detectors each running a schedule with various amounts of lights in each schedule and I’ve had no issues with them not working. The only issue I had was one motion detector is outside and the battery went dead. Replaced the battery and everything was fine.
