Wyze Headphones - Disable power on status light via app settings
I occasionally use the headphones at night. The power status light is bright and obnoxious.
It would be nice to be able to disable the power status light using the app.
Voice notifications are sufficient for me to know what’s going on.
[Mod Edit]: Title and request text modified to enhance search clarity.
That would be a nice option, similar to the camera’s. I voted for this as well.
For the time being, you could use a little piece of electrical tape over the light.
This IS what I have done in the meantime :slight_smile:
But it doesn’t stay fixed in place for long… and leaves a residue (the app seems a much better option if possible).
I didn’t want to recreate a topic on the issue. But did end up returning my headphones directly as a result of not being able to turn off the status light.
I should also add this status light is incredibly intrusive, especially on an airplane.
and sadly, the electric tape does not work on the White version of the headphones.
I hope Wyze makes an effort to disable the status light in the future. They are very good headphones, and it’s unfortunate this was a deal breaker… for me at least.
I just got them and these will go right back if this feature isn’t added.
