Hi
Is there a way to make headphones remember ANC state after reboot?
If I’m turning ANC off, after reboot it’s turned on. Even if I choose minimum ANC level in the app, after reboot it’s on max level.
Thanks
Hi
Thanks
a tip for everyone reading my question
just find out that after pressing 2 times power button on headphones the voice will tell you remaining battery level
