For any that will be installing the Wyze Floodlight, remember that it has the capability to add an additional V3 with a USB port on the underbelly of the motion sensor casing.
If you do not use this feature please ensure that the rubberized plug is pushed in all the way or you may get some water damage. As I was admiring my new device I noticed that the USB rubber plug out of box was not fitted completely in the port.
Just a heads up
