Wyze floodlight pro cam update suggestions
Suggestions for future update:
When atomization is selected, I can’t exit the setting unless the app is closed and reopened
In event recording setting, if all events is selected, an insect will set the motion detection off. Even reducing sensitivity to 50 did nothing. Sensitivity should be based on the size of an object not distance.
Should not have to subscribe to cloud for detection settings. “Smart detection” for doesn’t seem to pick up animals for example and switching to all events means bugs will set it off.
Is “smart detection” really “smart” ? Bad guys prowling around are not going to be obvious. In the county where I live they wear gillie suits and will crawl slowly to avoid detection or wear photo reflecting clothing ect.
I like the motion tagging and smart zoom but they both need a little work. The green outline is nice to see what tripped the cam but the outline looks a little thick and sometimes will overlay on the subject blocking the part of the view. When used with smart zoom the green box was hitting the top of my head when I tripped the motion and the smart zoom, zoomed in too much, cutting off parts of my body. Seemed like it was trying to get a head shot.
Another feature that could improve is : pinch to zoom. Seems to work occasionally on live view but not all the time. Doesn’t work at all when viewing the sd card feed.
