Is there a way to get my Wyze doorbell reconnected to WiFi without dismounting it and disconnecting the wires first then going through the setup ?
You should not have to remove it.
However, have you tried unplugging the chime and plugging that back in? The pro doorbell connects to the chime. The chime connects to your wifi. If you don’t seem to get connected, try moving the chime closer to the doorbell or closer to the router
@spamoni
Thanks…WiFi is OK now so I’ll try your method next time it Drops off WiFi
