Wyze Doorbell & Alexa Integration Bug
If you set the main Wyze settings with Alexa Integration, this will break the connection on the Wyze Doorbell (original) to the doorbell accessory. It will mention it cannot connect with the doorbell accessory, but as soon as you remove the Alexa integration, it works again. I feel like this has been an issue for quite some time, but continues to get ignored.
Another issue is the doorbell accessory schedule constantly being out of whack if it said outside of all day.
Are any of these issues going to get solved?
