Ok so my wired doorbell went belly up and I didn’t want to buy another setup, while I’m waiting for the wyze video doorbell in case I need a specific setup. So I took the contact off my side door, that we never use and did the Contact sensor water leak tester mod to it. Basically remove the magnetic glass ampule and add wires to those spots, there is a couple videos on YouTube showing how to do it, if you haven’t seen it. Hooked the wires to a standard basic doorbell button and put it in a plastic housing on the door trim. Now the sensor will normally show open. So I made a routine in the Alexa app that when the sensor closes it rings a bell and says someone is at the door. Now I have a smart doorbell for practically nothing. Sorry it’s only letting upload one image.
