While an expanded temp range might be useful, it wouldn’t be practical.
The batteries would drain incredibly fast in a freezer and they would not be effective. Battery operated Gagets do not like sub-freezing temps. This is why most IoT Freezer Temp Sensors are outside with a wired probe running inside.
There is another current Wishlist request that deals with this as well. To support it, follow the link, Vote at the top, like some posts, and add your reply post with ideas and use case description.
After making the suggestion to Wyze to improve the climate sensor I found the Govee Wi-Fi Thermo-Hygrometer battery operate sensor works perfect for my freezers. It has been 8 months since I installed the Govee sensors. My freezers maintain a -10 to -15 f temperature and I have not had to change the batteries yet. I just checked and the sensors report about 50% battery remaining.
I think the reason the Govee performs so well is their use of the venerable AAA battery rather than the CR2450, which spec should go down to -4F, but apparently doesn’t.
Just purchased the Govee thermometers which use the venerable AAA battery instead of the CR2450, which spec states should go down to -4F, but apparently doesn’t. We’ll see how they do…
Add me to the list of those who would like to see a weatherproof WYZE temp sensor with a wider range and possibly with a separate probe for freezers or liquids. The description mentions “monitoring attics” but 104°F is not hot enough for most attics.
I’d also like to see WYZE sensors that react to a “dry contact” (zero voltage) opening or closure …should be easy to modify the door contact sensor to do that…or that provide a low voltage low amperage contact that closes or opens upon signal from WYZE app or devices.
I am currently using the Climate - Sensor to monitor my Fridge and Freezer. I understand putting a RF device in a cold metal box is problematic at best. (Faraday cage and battery temp operation) The current Sensor also has temperature limitations in its range of operation. I am hopping that future models will be constructed to operate in these environments or that an external sensor could be attached vis wire. Below is the Name of one that operates from -40°F to 257°F. Wyze make great products and i hope you will consider this as a worthwhile upgrade.
