Wyze Chime - Add Ability to Turn Off/Disable Blue Light
Please add the ability to disable or turn off the blue led status light on doorbell chime accessory. Currently there is no way to disable this light within either the app or button on the device. It’s hard to sleep with this device in a bedroom because of this device.
black electrical tape …
That’s what I’m currently using. I consider this a band-aid solution until they update the app allowing users to switch this light on/off. Hopefully, this can be handled with a software update and not a hardware update.
Agreed wholly. The LED on my Doorbell Pro chime is brighter than a nightlight. It radiates down the hall and is annoying. I don’t want to use tape, I want the correct fix.
