Wyze Can Pan Needs Resetting
My Wyze Cam Pan has to be physically reset after momentary power failures, is this a common failure? Is there a fix to automatically reset the Pam after a power failure?
What’s the cause of the frequent power failures? You might be able to rig a smart plug to cut power and then reapply power a short time later, but the frequent power failures might also affect the plug.
Mostly weather related power fluctuations cause my problem. I do not have to reset the Wyze Cam v2’s but the Pan has to be unplugged then plug back in to restore it.
