Wyze Cams Viewed On TinyCamPro on Google ChromeCast (New Version w/ Remote) on a TV
It seems you have a fair grasp of the issue at hand. Maybe you can help improve my current set up. Basically, I want to view several of my outdoor cams (Pan V3s) at the same time on a TV screen. Currently, I achieve this by using TinyCam Pro and Chromecast. I don’t have Alexa as I opted to go the Google home route.
I had set this up before with no issues, and in simple relocating my TV (across the same room and closer to the WiFi point - Google mesh) and now I seem to drop every 4hrs or so. It seems like the app crashes and makes no attempt to reconnect. I’m more than open to new ideas/tips/tricks.
@SlabSlayer I’ve flipped the decoder to hardware and it helps load the cams, but I’m being hit with some instability. Of course this happens right after I post about how I think I found a way…story of my life.
Thanks to anyone any everyone who throws in their 2 cents!
Have you tried setting Tinycam Pro toggles to main not auto for stream profile? And/or tried assigning a channel number to each camera in Tinycam?
