I have the wyze cam and the wyze cam pan. I notice that my wyze cam has a clearer, more crisp picture. Both cameras are 1080p though. Why is the video on the wyze cam pan of lesser quality
I would recommend checking out this topic. It may answer your question.
Wyze Cam v2 Component Change - Transition to JX-F23 CMOS Sensor
Beginning in mid-October 2018, there will be a change to the CMOS sensor in Wyze Cam v2. We will be transitioning from the JX-F22 CMOS sensor to the JX-F23 CMOS sensor. Overall, the JX-F23 sensor is a newer and more optimized sensor that will provide the same or better image quality as the JX-F22 sensor, particularly in low light settings. This change will have some impact on Wyze Cam v2’s performance, and will have a slight cost b…
