Wyze Cam v3 Firmware Beta Test 2/2/5/2025
Version: 4.36.14.2725
What’s New:
  • Security improvements
  • Fixed a bug that caused the live stream connection to fail
Like the previous beta 4.36.14.2589, this latest beta Cam V3 FW 4.36.14.2725 update will still cause the camera to restart itself automatically when the internet is out for more than 30 minutes. Once the camera is restarted then it will start recording in 20250221 folder with the timestamp of 2025-02-21 21:39:10 in the microSD card. It will overwrite the old footage. Alternatively, you can access the footage on the Wyze app as well on February 21st 2025 starting at 9:39pm. This date and time is only unique with this particular beta firmware as that should be the firmware build date.
