Wyze Cam v2 click sound
Hello everyone, like somebody know I try to get wyze while my friend in USA. Anyway, finally I got it and try to make some experience BUT I realized something when I plugin after cut the energy. It clicks 2 or three time orange led appears and blue flash and it shutting down. Is it normal or just need some setting.
Btw, I only use it after cuting the energy just “setup button and qr code scan” otherwise its shutting.
Thanks for any comment. (last firmware updated)
So I take a video : https://streamable.com/cdy19
It’s the mechanical IR cut filter clicking into and out of place. It allows for the best color during the day, and the best night vision at night.
Yeah I searches click voice but I mean it’s not powering on if I didnt scan qr code after electric gone. Just clicking and shutting.
Just watched the video, clicking is the IR cut filter and is just part of a self test I think, but have you pressed the reset button on the bottom? You should then hear “Ready to connect”.
If you mean “Setup” button yeah I am pressing all the time and re-read code when power gone.
When your power(electric) gone are make all steps again like first open?
I FIGURED OUT
when sd card not insterted it can’t boot up cuz I think some settings installing on sdcard.
Now I scanned qr when sd insterted and connect after I cut the power and then re plug to power now IT BOOT UP AND WORK
I’ve got several without SD cards in them, and that shouldn’t happen. But it ain’t broke, go with it. I did however have one that lost it’s memory everytime it lost power too. But I just sent it back because it was free with amazon prime.
I have one more wyze v2 I will try it too if it has not this problem, when my friend go back to USA (I’m living in Turkey) I will send it to wyze for repair
The problem still continues, is there anything you can recommend @UserCustomerGwen
EDIT: Now I realized its not just clcik issue after re-plugin to power.If you restart/cut power you must be re-setup like first time.
I would recommend contacting customer support for this one. Definitely sounds like something is wrong! Sorry about that, @mehmet.akif.simsek.
Wyze Customer Support
