When you click each of these, it should download a file ending in .zip to your computer (you need to be on a computer to do this).
Expand the compressed .zip file. This is usually done by double clicking it. On some computers, it will expand automatically. The result will be a file called “demo.bin”. If that’s not the exact hame it gets (eg, sometimes it ends up demo.bin.bin), then rename it to “demo.bin”.
Insert your microSD card into the computer. Copy the demo.bin file over to the top level of the SD card directory. Make sure it’s the only file/folder there. Delete any others.
Also note, there is an issue with the size of the SD card. My larger card wouldn’t get the blue light after holding the setup button. My 2GB card did. Fortunately I found this on another solution board, But it would be helpful to update the instructions.
We apologize for the firmware trouble, folks. We’re looking into the Wyze Cam Pan firmware and we’re working on a fix. If you are having trouble with motion detection after upgrading, please send us a log through Account > Help & Feedback > Report an Issue. Then please give me your support ticket number so I can give it to the dev side. We’re sorry about this and will fix it as soon as we can.
