Wyze cam person automation
I am trying to set up automation to turn light on if person viewed by cam. It will work with motion but not person. It keeps giving a warning.:warning: I have tried several different Wyze cam types … same error when person selected in automations as trigger.
I am on Can unlimited Pro and have tried recreating automation several times. As well as restarting cams and app. I also have same issue from iPad and iPhone. I have also tried adding a time restriction and an additional action and changed lights ..
Suggestions?
Just got it to work with old Wyze cam v3 …
So why not duocam and some others ..which I will list including doorcam pro, cam v4…cam OG
Hi tc10,
Could you share what error message appears when you tap on the automation with the warning icon?
Alternatively, you can submit a log to help us investigate: Account > Wyze Support > Submit a Log > Wyze App & Services
ifI click on the yellow triangle this is the message. When I open the automation nothing is highlighted to fix. I tried changing each item. When I changed from person to motion, the error msg went away. I get the same error message if I choose pet instead of person.
Log file 2131923
Thanks for submitting the log! Based on what you described, this sounds like it might be an issue with the troubleshooting tool’s detection rather than the automation itself—your automation should still work properly. The log will help us investigate further.
Thanks @WyzeHaoran
