Wyze Cam Pan V3 -- Could you please add a position lock?
It is very nice to be able to pan around the room occasionally, but it is also annoying when you have positioned the camera perfectly only to move it later accidentally. Since it seems that touching the image or the round arrow pad accidentally is very easy to do it would be helpful to have something like a checkbox to disable the pan. Thanks!
Set your first waypoint as your desired view and angle. Or find your desired view, and then enable the detection zone. That will save that view until you change those things later.
