So I’ve been having an issue with the Wyze Cam Pan. It started months ago, I’ve tried resetting the camera, to no avail. The problem is, whenever I set the motion detection zone, about a day later, the camera will have turned either to the left or right a little. I will reset the detection zone, and it keeps happening. I’m not sure if this is an issue with software, or just my camera. I do have the camera mounted outside, protected by a rubber case and an eve. Not sure if that is related to my issue.
I have the same issue on a pan cam in my kitchen. It seems to reset (power cycle) itself every 2-4 days, and never returns to the original focal point.
At first I thought it was a bad PSU, so I replaced with my other pan cam’s PSU. No change. Reset the camera and installed latest firmware. No difference.
I’m thinking it may be some sort of bug/glitch with pan cam, cause now my other pan is doing the same thing.
