Wyze Cam Pan, Any way to limit what the shared users can control? Can you block them from being able to use the sound feature so they can not listen in? Or block them from using the mic?
I would think a limited set of toggles could be added for additional user control. Have the limited user as the standard share option, but add an advanced user share under the individual users to open an advanced share setting. The pan cam would have slightly more options to select from but options. For a power user (can do anything but remove the device), then toggles that allow playback, allow audio, allow speaker control, and allow motion control (for cam pan)… That would probably cover most of the user control requirements.
