Can you guys help me with the camera settings in the Wyze App? I am not trolling here or wasting your time, I truly want to know everything under the settings and that’s why I am asking.
(1) First thing, what’s the best settings under" Detection Sensitivity"? Select 100 Far and High under the distance and sensitivity? What’s image sensitivity?
(2) Event Recording, Check the “Detects Motion” right?
Under Smart Detection, most important is the Person & Package Detection?
(3) Recording Cooldown, is to be set to" No Cooldown"? No Cooldown means non stop recording without break when there is a motion that is detected?
(4) Advanced Settings, “Night Vision Mode” should be on Auto? What’s the MicroSD storage option for and why? It will keep the recorded videos for ever until the MicroSD card storage limit is reached? How long will my recorded videos under events remain in the Wyze App without the SD card? 14 days only?
What is the " Sync Time" for and what does it mean?
(5) Notifications, What is AI Events? What means Detects Wyze AI Events? should I check it on?
What is Detects Any other Motion? Check it on?
(6) Travel Mode, It says the camera can record without wifi or the base and with micro SD card? Is it true, the wyze cam outdoor will detect motion and record videos even if is is not connected to a wifi and no base required?
If true, Why bother with base and home wifi since it can detect motion and record and save videos without internet and the base?
Thanks
