Wyze Cam Outdoor & Base Station, Wyze Headphones Firmware Beta Test 5/10/2021
Wyze Cam Outdoor & Base Station:
Firmware Versions:
  • Wyze Cam Outdoor: 4.17.1. 56
  • Wyze Base Station: 4.16.1. 27
What’s New:
  • Adjusted the image sensitivity so that it’s easier to trigger motion when the sensitivity is set to low (around 10)
  • Removed the push notification when the camera is fully charged
  • Disabled the DHCP server while the base station is not pairing or in Travel Mode
Suggested Test Areas:
  • Setup
  • Motion detection
Wyze Headphones:
Firmware Version:
  • 2.1.133
What’s New:
  • Fixed a bug that caused the headphones to reboot during calls
  • Improved the auto-pause algorithm
Suggested Test Areas (optional and for alpha/beta only):
  • Take calls on the headphones with two devices connected to them at the same time
  • Auto-pause and auto-resume when you take off and take on the headphones
I may need to roll back one of my WCOs. It apparently failed upgrade but even though not seeing updated camera version the base station upgraded anyway. I’ll try a power cycle first… it is at a remote location so won’t know until next weekend.
Another oddity… affect cameras shows up as “This device is offline”…clicking on it gets to video (3/3). Device info for cameras shows active signal strength and you can attempt another firmware update but it doesn’t work though.
EDIT: It finally pushed through the firmware and reconnected. Impressed it recovered on it’s own.
“image sensitivity” Got my first person detection from the street, B4 only worked in front yard.
“camera is fully charged” Thank you! :slightly_smiling_face:
