Wyze Cam OG & OG Telephoto Firmware Beta Test 1/5/2024
Wyze Cam OG:
Version: 1.0.80
What’s new:
  • Fixed a bug that caused the camera to reboot due to microSD card corruption
  • Improved Wyze Web Portal connectivity
  • Bug fixes
Wyze Cam OG Telephoto:
Version: 1.0.80
What’s new:
  • Bug fixes
Installing via the firmware updates page and remotely. :slight_smile:
Wow, just got done, install was quick and painless. Will report of I see issues.
“Firmware is being updated”. Recorded on nearby cameras as all three of my OG-Tele cameras were updated. Went quick and all working.
As experienced by others, very quick update and seamless restart/online process. Camera working well so far.
updated last night, went fast and no issues. 1 OG and 2 OGtel.
today all still working well. will update if anything found.
I’m noticing car headlights & light wash on the yard are becoming a person again with smart detections.
I have alarms setup and a flash from my motion light outside set it off as a person detected several nights ago. All alarms off for now.
Tonight an OG caught headlights wash at the edge of yard near the road and called it a person.
When first installed, some months ago, that was an issue, but has been stable for quite a while with lower sensitivity settings etc. their all at 60 presently.
I have never experienced the reboot bug caused by corrupted SD that I know of. I have 6 OG and 1 tele OG on 1.0.80.
What I am experiencing on one OG only, is occasionally it stops recognizing the SD is there.
Same cam happened once before, I shrugged and replaced the SD. Cheap SDs. The card was good in the computer though. Wasn’t the card.
It happened again yesterday, this morning I removed the new card and reinserted it. It beeped and was okay again. I’m guessing that a month or so passed since the last issue occured.
May just be a failing or bad reader. Haven’t decided if I’m going to support yet. Will watch it for a couple weeks or months and see what happens.
