Wyze Cam OG - "network encryption not supported"
Hello
I have a total of 9 Wyze cameras and 1 Wyze Chime connected to my network, and I have consistently used Wyze product for at least the last 6 years.
I have a wyze cam OG that I purchased in July of 2026, As of October 6th, the camera went offline from my network. I attempted to delete and re-add the camera, and now the camera only gives “network encryption not supported” error during setup. Please note that prior to 10/6, the camera was added and functioned normally on my existing network.
1.) I am only using WPA2.
2.) I have attempted to reset the camera back to “factory settings”, but this error still persists on setup.
3.) While I have seen suggestions to drop the security on my network to WPA, I am reluctant to drop the security stance of my entire network for one camera.
Any suggested troubleshooting steps from the community, or should I just warranty this with Wyze?
Thanks
If it helps any
I had purchased a NEW OG ( New version they released compared to OLD version OG Cam)
I had experienced issues with the 1st one, returned that, and ordered another, same problem, spent a lot of wasted time, trying to figure out what was wrong with the NEW model OG cam go so fustrated with it, I returned it, and purchased a V4 cam…That V4 model has been working fine since.
Now the 2nd part
My two previously Working well Old Model OG cam, that have been rock solid for both, had em since 2023 and 2nd one, since 2024, in the last few weeks, I have been experiencing “” Offline"
I unplug the power, plug back in, same issue
Go through this a few times, then it starts working again
Only to stop again after a few days with the same issue
Both of these older OG model cams were rock solid, until the last 2 weeks or so, since all the Wyze Updates were released.
NEW OG cam, you may want to replace it with the NEW V4 and be done with the problem.
New OG’s seem to have issues
WPA2 is fine, that’s what I run on my IOT network and never any issues.
Do you have any special characters in the SSID or password? Most are not an issue, but occasionally some devices won’t like a certain one.
A weak signal can also result in that error message, which could mean the cam’s wireless radio is dying, or that there is something else near it interfering.
As a test, you could try creating a guest network on your router with a very simple name and password, or even try using hotspot on a phone, just to rule out that possibility. If possible, test with the cam close to the router/phone.
If it won’t work even when closer and with simple credentials (or it works until you move it a bit further away), I’d suspect the wireless radio in the cam may be dying.
Thx for suggestions. No special chars in the SSID, password has letters numbers and punctuation, but no special characters.
I have a pretty robust mesh network with hardwired backhaul for the first leg, then wireless after that, so coverage and bandwidth is not an issue. Once again, 9 other wyze devices continue work fine, and this one stopped on 10/6. My router’s firmware has not been updated since early september, and I do not allow for auto updates. Trying this with my 2.4ghz only guest network and got the same result “network encryption not supported”.
Thanks again for the suggestions, but at this point I am very reluctant to continue to tamper with my network for the sake of this camera - starting the warranty process with Wyze since I just bought this in July.
Yeah my guess is the wifi chip in the cam crapped out. You’ll frequently see that message if you try to join a network with any device when you’re out of usable range, because the negotiation gets corrupted. If it is in warranty, they’ll probably make you jump through a couple hoops, then just send you a new one and tell you to dispose of the old one.
