No problem. I often get irked in the same way.
If you’d answer those who are trying to help this topic wouldn’t devolve.
To reiterate:
I did answer/post it initially
Latest releases of Firmware & Software builds
And I dont install Beta builds, as most people dont.
The Forward / Reverse issue after the latest APP build, is not such a big deal/show stopper , I will wait until they release their next update.
As you have mentioned, Wyze Support rarely every reads the posts, so really anyone posting issues, shouldn’t expect a fix from Wyze anyway.
In reality, I really shouldn’t have made my initial post, since it is related to the latest software release issue, there is nothing anyone on the Forum could do to fix it, as they are not the Wyze software developers/coders.
Also as you mentioned, Wyze doesn’t support Emulators, and one of the 2 devices I have the 30 sec Forward /Reverse issue the Wyze APP is running on an Emulator (It worked fine on the emulator since installed, but the most recent APP release, 30 Sec Forward /Reverse does not advance video)
So in short I shouldn’t have posted the issue, and just wait for future Wyze updates, that will fix it,
