Wyze bulbs in a remote controlled ceiling fan?
Hello. Is it possible to use Wyze bulbs in a remote controlled only ceiling fan? I have no issue using the bulbs in your traditional pull string ceiling fan, but no such luck in a ceiling fan that is 100% remote controlled. By the way, the wall switch is always in the on position.
Almost all manufacturers of smart bulbs don’t recommend using them in ceiling fans for two reasons. RFI/EMI from the fan motor, and the vibration caused by the movement of the fan. This is a YMMV situation.
If you ceiling fan has a remote that can turn the lights on and off, use an IR blaster like the one Broadlink sells to control your lights with your phone and Alexa.
