Will these new light switches work with ceiling fans that take more power than a regular light?
I have used and returned multiple brands of smart switches saying they do work but when installed they do not give the fan the correct voltage needed to run which can cause failure or fire.
Would a Wyze switch be a good fit for a ceiling fan? Mine has a heavy-duty multi-positional switch on it to adjust the fan speed. Wouldn’t the fan run at maximum all the time if connected to a Wyze switch?
The switch is rated for 120V/60Hz/15A. What voltage did your other switches send to the fan?
