Wyze Bulb V2 “night light” scene vs 1% brightness
I’ve noticed that on the Wyze Bulb V2/Wyze Bulb White, the lowest brightness setting (i.e. 1% brightness) is not actually the dimmest option for the bulb. The “night light” scene is much dimmer than 1% brightness.
This means that as far as I can tell there’s no way to access the dimmest bulb setting through a rule or using Alexa, which is frustrating because I like to set the nightlight dimness at night but can’t do so with my “bedtime” Alexa routine. Is there any workaround for this using rules/Alexa, or any chance Wyze can fix it so that when the bulb is set to 1% it’s actually the dimmest the bulb can go?
