I had a one-minute power loss overnight and realized that my Wyze Bulb turned itself on (it had been off before the power loss). I went to check the “Power loss recovery” settings and was surprised to see that it was set to “Turn on after power recovery” instead of “Maintain previous state,” which I had manually set it to about six months ago. I know this because the same thing happened then and after a brief power loss the bulb turned on, so I set it to maintain previous state.
I want to suggest that a “Turn off” option be added as well as know if anyone else has seen Wyze Bulb settings not stick. Ever since the first time, I haven’t disconnected or reset that bulb or anything like that, so I’m surprised to see the setting changed.
