On Mac Mini M4 with Sequoia, v3.2.6 does not accept my login that still works on my iOS and Android devices.
Very frustrating.
Allowed me to “sign in with Apple”, but said I had “no devices”.
Used to work several weeks back.
Grrrrr.
Why don’t you try and sign up with the Wyze account instead with Apple. I notice you have the new M4 MacMini, did the app worked before on it? Might be the new chip architecture. It works fine on my M2 MacMini with Sequoia.
I did that, several cycles, my old user/password gets rejected then after about 3 tries it locks me out for 15 minutes!
I don’t want to reset password which is working fine on multiple other devices.
The M4 Mini is new, possibly my last login was with an M1 Mini on Sequoia.
I think that’s your problem. I am in the graphic design industry and I vividly remember when Apple switched from Intel to Silicon chips. None of the Adobe software was compatible and the whole design/prepress industry was holding off until Adobe updated their software to be compatible with M chips so they can upgrade the hardware. Every version of the M chip brings new challenges so you have to give it some time for everyone to get on board.
