Can I install wyze cam app on Microsoft surface 3 tablet. I can’t seem to be able to do that.
You can only install the Wyze app on devices that run Android or iOS. You may be able to install it within an Android emulator such as Nox or BlueStacks on your Surface.
Not all tablets is compatible with the wyze app software. I installed an older version of the wyze app software and it worked but it had a major impact on the screen quality. Also i cannot do any version upgrades because then the system tells me that the device is not compatible with that version software.
