**When I arm ”I’m away” with the app, if the system is currently disarmed, the the hub will announce: “armed away" as expected. In the app, it will display the “system arming” spinner, which just keeps spinning. At the screen top right, the “I’m away” button will be dark blue.
**In the app, after a few mins, the “system disarming” spinner will activate, and the checkmark will appear indicating disarmed! At the screen top left, the “Disarmed” button will be green.
It will keep repeating this “system disarming” spinner behavior every 40-45 secs or so…
*Note all this time, the alarm is ACTUALLY ARMED, and opening my door WILL trigger the alarm, and I cannot disarm with the app. I have to disarm with the keypad.
*I first noticed this problem ~ 2 months ago… Annoying…. help.
This issue persists and I’ve been unable to track down any resolution. Wyze has simply stated return your hub to us for an exchange. However, the arm/disarm works via the keypad fine. It’s only via the app that arm / disarm fails. I’m not absolutely positive but I suspect this behavior began when I turned on 2FA as requested by Wyze.
i got mine working now after they sent replacement and had to re-add all the sense devices. I found out that all my other sensors connected on the hub were not updating since then but they were all online (door sensor, climate sensor, motion sensor).
